I am redesigning my antec 1200 fan layout and direction and wanted to know what is my best bet.
My current setup consists of 7 3000RPM 133CFM Scythe Ultra Kaze 120mm x 38mm fans 3 in front bays blowing over hard drives into main compartment of case. I then have two blowing in from the side panel onto the motherboard, I have 2 rears blowing in as well only using the top 200mm fan as exhaust. I also have a 60mm fan for my north bridge and 2 more 60mm that are on a zalman ram cooler as well as the 110mm zalman 9700 cpu cooler aiming up at top fan.
My main heat source is my CPU and ati 5970. I do plan on OCing my q9400 back to 3.6-3.8ghz at stock 2.66 to 3.4 my idles where high 20'sC low 30's full load never passed 45C with stock fans and zalman cooler So I'm assuming with these monster fans it should be lower
I'm waiting on my replacement motherboard for a few more days and wanted to get it right before hand but will be changing as needed when installed and up and running.
I was talking with a computer tech at Fry's about directionality of airflow and he through me a curve ball by suggesting using all but the top fan as intake. He said to try it like that and then with the rear and top being exhaust since essentially you want only one place for intake and one for exhaust to keep proper airflow instead of pushing ind pulling from a few spots. I wanted to get some other people perspectives and thoughts before I make a final position on airflow layout. I do plan on adding quite a few cold cathode 12" lights as well as 2 12" meteor LED lights if that make a difference in this question.
My motherboard is a Gigabyte EP-45 UD3P 775 chipset
8gigs ddr2 1066 gskill
ati 5970
q9400 CPU
Antec CP-850watt PSU
6 SATA II HDDs 7TB
1 30GB OCZ Vertex SSD
2X 27" ASUS HD monitors
logitech X540
ati 5970
q9400 CPU
6 SATA II HDDs 7TB
logitech X540
