So i decided to cut some holes in my case and hide to wires so the air flow would be a lot better.
I've had this case for 2 1/2 years now and i noticed a lot of dust been collecting and the air flow is pretty bad. i had 2 fans from the front sucking air in and the back and top fans to blow air out.
Here is the before of inside.
Back of motherboard.
After of inside.
After of outside
My temperatures have decreased 8-10 degrees. I got to move my SSD to very bottom on computer because i didn't notice there was a mount for it.
Problem is i still have wires over lapping mother i was wondering how the hell do people hide those. I tried running the front USB and Audio port cable to my mother board but its on the very end of the motherboard. I can't even run it from the back. and the 6 pin on the mother board on top of my cpu i don't get how people run the cable in the back without anything showing.
any help would be appreciated. first time at cutting so i don't even care i free handed the cuts as you can see. Im thinking about getting a enclosure to move my HDD to the 5.25 bay. My CD drive is not plugged in because i don't use it.
Spec of computer.
CPU fan: 212+ EVO
Motherboard: Z77 extreme 4 asrock
case: Antec 300 i think the new edition because it has a cutout behind motherboard
After of inside.
After of outside
Spec of computer.
CPU fan: 212+ EVO
