N Nada190 Distinguished Oct 14, 2013 435 0 18,810 Jan 18, 2014 #1 Is there any way to upgrade it's power supply? 90W is just so little. Or is there another case of the same size with a bigger PSU?
inzone Champion Mar 12, 2011 14,971 1 51,960 Jan 18, 2014 #2 http://www.newegg.com/Product/Product.aspx?Item=N82E16817338081 http://www.newegg.com/Product/Product.aspx?Item=N82E16817338063 http://www.newegg.com/Product/Product.aspx?Item=N82E16817104145 You can check out these power supplies to see if you want to go with one of them or you can look at the rest on the mini-itx page at Newegg. Each one will give the over all measurements of the PSU so you can tell if it will fit your case. Upvote 0 Downvote
