I have an 8800GTX running in my P182 case, but the temperatures are just insane (75 idle and 104 max with GPU fan at 100%). It is likely an airflow problem as the temps drop to normal if I remove the side panel (58 idle and 78 max). Here is a diagram of how I think the fans should be blowing:
This makes the most sense to me, but I am not sure if the top and rear fans are blowing out of the case by default. Does anyone know the default directions of these fans? Also, does anyone have effective 8800GTX cooling in this case with the stock HSF?
