I have recently bought and assembled a new system, which included the case Antec P183. One of my goals for the build was to have a quiet computer.
However the overall sound level is a bit higher than I expected, and I did suspect the CPU or GPU fans at first, but after doing some testing with stoping the fans with my fingers and listen to the changes I noticed that most of the noice seems to come from the top fan. In the chassi there is two builtin 120mm fans, one at the back and one at the top. The backend fan does not seem to produce the same amount of sound, but I am not really sure.
The PSU and CPU fans are virtual noiceless and the GPU fan is just a little higher.
If I stop four fans (cpu, gpu and both case) manualy the whole system is very very silent, but when releasing the top one the noice goes up. Both case fans are set to low speed.
However, since Antec really pushes for this case to be very quiet it seems a bit strange to me that it sounds so much.
Is there anything I can do or is there anything that could be wrongly setup by me while assembling the build?
