I currently have a Realtek 8821AE Wireless LAN 802.11ac PCI-E NIC and i have accidently broke the antenna for it. I was wondering what other antenna can i get to replace my previous one.
I'm not sure the plug that your NIC uses, but it's most likely RP-SMA. So just search for RP-SMA antennae, make sure that you get the correct band as well. It's pretty simple to swap out though.
