I just moved my build into a new case and things were working great before the move. After the move however, my Bluetooth range was pretty spotty, with my keyboard and PS5 controller now losing connection unless I’m a foot away from the PC.
My asus tuf x570 pro mobo has wifi 6/bluetooth built in and upon inspection I noticed that one of the connectors that I screw the antenna to on the back of the mobo itself is extremely loose (I assume that when I screwed the antenna off before moving into the new case, I somehow loosened the mobo’s connector). The connector from the antenna is super loose and a few turns just makes it fall off - so I assume this is causing the Bluetooth connection issues I’m encountering ?
Does anyone know how to go about fixing a loose wifi/bt connector on the back of the motherboard? Is there a way to tighten it?
Below is a stock image of the motherboard’s IO. Its the top gold connector that is loose:
https://www.asus.com/websites/global/products/zz4hgtbqrmqdbkun/back_io.png
Help would be much appreciated. I love my new case but this Bluetooth thing is bumming me out 🙁
