any recommendation for silent cooling for i7-5930K used for max 3d rendering stress.
Calin Cristian
23
Hello all !
Which are the best "no noise" radiators and cases that suits the i7-5930K ?
If possible to cancel noise at max.
It is about the non fan radiator or about the pc case ?
Also, any idea is the"no fan" cooling system is ok to use with the i7-5930k because I use this cpu for 3d rendering so the CPU will be all the time at MAX.
Thank you in advance and I wait your answers !
There are not any for that kind of use. They really only cover low voltage low speed CPU's not expected to be put under stress on a regular basis. You would be better off with a cooler like the noctua or be quite, and a silent styled case. Won't be completely noiseless but still not noticeable load.
