I am Looking for a 120mm PWM Fans Preferably ARGB for my Arctic Freezer 34 esports also Preferably 25mm Thick for Clearance. Any Suggestions would Help! Thanks.
Look at arctic since you already have their cooler, they have some of finest ones.I am Looking for a 120mm PWM Fans Preferably ARGB for my Arctic Freezer 34 esports also Preferably 25mm Thick for Clearance. Any Suggestions would Help! Thanks.
They do have ARGB fans but the new Bionx ARGB cant fit into the Heatsink, and Im not so sure about the P12 Argb if its for a Case fan or if its ok to put in to a heatsinkLook at arctic since you already have their cooler, they have some of finest ones.
With Arctic, F are case fans. P are universal with even better flow than F and certainly better static pressure. If usable for radiators, certainly good enough for air coolers.They do have ARGB fans but the new Bionx ARGB cant fit into the Heatsink, and Im not so sure about the P12 Argb if its for a Case fan or if its ok to put in to a heatsink
Oh I see, I just wanna ask a Follow-up question tho, the One that I bought is a Single Fan version of the Cooler, although the Package came with another 2 extra set of Fan bracket, Can I use the extra 2 Fan bracket on the other side for a "Push-pull" Configuration? My motherboard is Asrock b550 phantom gaming 4, Im afraid that if I add another fan for the Pull it might not fit because of the VRM Heatsink, so I just want to ask for your Answer on this if it will fit or notWith Arctic, F are case fans. P are universal with even better flow than F and certainly better static pressure. If usable for radiators, certainly good enough for air coolers.
Second fa helps a little and ma not be worth extra noise but if it fits and you are OK with it, by any means put it in but make sure that it's speed is in sync with push fan. either thru combined cable or to CPU_AUX header. Fans should be able to lift up few mm for clearance.Oh I see, I just wanna ask a Follow-up question tho, the One that I bought is a Single Fan version of the Cooler, although the Package came with another 2 extra set of Fan bracket, Can I use the extra 2 Fan bracket on the other side for a "Push-pull" Configuration? My motherboard is Asrock b550 phantom gaming 4, Im afraid that if I add another fan for the Pull it might not fit because of the VRM Heatsink, so I just want to ask for your Answer on this if it will fit or not
