Build Advice Any suggestions for my first build?
SmokeeDN
16
Ideally I would like to keep the price below $2000 CAD, I don't plan on moving to 1440p anytime soon, I just want really solid performance in any game at 1080p 144 Hz using relatively high settings. I know the power supply is a bit much but I will probably want to upgrade in the coming years. Are there any components that would work better or anything I should get rid of etc? Thanks a lot!
https://ca.pcpartpicker.com/list/m4GXcY
Everything looks good however for 1080P/144hz on higher settings you'll need to overclock that CPU and the EVO 212 really isn't up to the task. While it would go about $30 over your budget the Scythe Mugen 5 would be able to handle a 5ghz+ OC with safe temps.
CPU Cooler: Scythe - Mugen 5 Rev. B 51.17 CFM CPU Cooler ($101.58 @ Newegg Canada Marketplace)
Total: $101.58
Generated by PCPartPicker 2019-04-05 10:39 EDT-0400
The Intel Temperature Guide by CompuTronix has everything you need to know to overclock as well as links to the software needed to do so.
https://forums.tomshardware.com/threads/intel-temperature-guide.1488337/
