[SOLVED] Any suggestions on a sturdy case that and has good airflow, will support a 310mm graphics card, NO RGB/LED or Glass/Acrylic side panel.
Pythonbites
87
I'm rebuilding my computer in a new case with a ROG Strix GTX 1660ti. I want the case to have good positive airflow options that will cool the graphics card and the Ryzen 5 2600x in there, and the intakes to have decent dust filters. I would prefer to have at least 2 fans of any size included. My budget is around 70 GBP ($85) but if I have to go a little higher ($10 max) I can. Thanks for any replies.
What is your motherboard? :)
The Fractal Design Meshify C is a good high airflow case that will fit up to a 315mm GPU and includes 2 - 120 mm fans:
http://www.fractal-design.com/home/product/cases/meshify/meshify-c-bko
It is on Newegg for $85:
https://www.newegg.com/black-fractal-design-meshify-c-atx-mid-tower/p/N82E16811352085
Or possibly:
Fractal Design Focus G
https://www.newegg.com/black-fractal-design-focus-g-atx-mid-tower/p/N82E16811352069
The Cooler Master MasterBox Lite 5 RGB looks like a decent option as well and includes 3 - 120 mm fans:
https://www.newegg.com/black-cooler-master-masterbox-lite-5-rgb-atx-mid-tower/p/N82E16811119325
I despise the design on that case. The feature set looks great, but I do not like the outside design. Especially the huge logo at the front and silver standoffs.
EDIT: I meant the Meshify C, the Coolermaster one looks great, thanks. Although, I don't like the glassy, RGB orientated design.
