Any way of using an M.2 NVME SSD without an M.2 slot or spare PCI-E slot?
TristanKing
57
I'd like to eventually upgrade my motherboard and CPU, but not at the moment as I'm looking forward to either Kaby or Cannon Lake.
However I'm running out of SSD space. I have one 500gb SSD and another 250gb (along with 2 1tb HDD for data and backup) so I need to buy more storage, but I'd like to get an M.2 NVME SSD instead of just getting yet ANOTHER sata one...
I also only have 1 PCI-E slot with my GTX 1060 in, so I can't use that... (Or can it be split?)
Is there some way to link multiple Sata cables to an adapter or something? Or am I stuck until I upgrade my MB?
My build - http://uk.pcpartpicker.com/list/TvL44C
M.2 is a size format, not a performance thing.
It does happen, though that X1 has, as I recall, the transfer rate similar to sata.
It takes a X4 slot to be able to go some 4x sata speeds out of the new NVME devices.
That is for sequential operations.
For random I/O, which is much more important to windows, the slot speed is not that important.
I think if you are going after high sequential speeds, you will want to look into a more capable motherboard
So if I decided to get a 1tb SSD like one of Samsung's new 960 Evos, and put my OS and most of my applications on it, would I be getting worse or better performance than my 850 evo on SATA?
I'm only bothered if it's noticeably worse, as at least I'll have more storage, and eventually I can upgrade my CPU and MB.
If I am not mistaken, the 960 EVO is a nvme m.2 device only, and really should be used on a motherboard with a X4 pcie capability. Your motherboard does not have that ability.
Not to worry, though. Larger ssd devices perform better than small ones, particularly with update activity.
a 1tb drive for everything is a very good idea. Performance will be excellent, and the simplicity of managing a single storage space is very attractive.
You can buy a 1tb 850 EVO for about $350, or a 850 PRO for $410 or so.
If the price difference is not a burden, buy the PRO, it is slightly faster.
Really, though, you can not tell any performance difference from the EVO without a synthetic benchmark.
