Any way to connect USB headphones to 3.5mm Audio Jack?
LLL7
Sorry if this is too downed, but I cannot find a straight answer anywhere I look. Is there a converter cable that will connect:
My USB Headphones (they have USB male on the end) need to be able to connect to a 3.5mm audio out jack (female hole in the TV that outputs the TV's audio) on my TV. I have a male to male 3.5mm cord if this comes in female form, as well. Is there any converter that will do this (preferably for cheap)?
I found this on Amazon/Ebay, but ships from china over a month and all other similar ones ship from around there, and have unfavorable reviews:
http://www.ebay.com/itm/3-5mm-Male-AUX-Audio-Plug-Jack-to-USB-2-0-Female-Converter-Cable-Cord-Car-MP3-HM-/181488790730?pt=US_MP3_Player_Cables_Adapters&hash=item2a41932cca
The problem you are running into is that you are going from analog to digital. The product you listed is not going to work, you would need an active adapter and at that point you dropping more money into a problem then you probably want to.
Your best bet is to either pick up a headset that uses analog or use regular speakers. Which headset do you have? Sometimes they come with or sell a converter which might be more reliable then what you will find on ebay.
