K kebbz Honorable Jul 27, 2012 212 0 10,680 Aug 2, 2013 #1 I'm curious as to what the result would be since components produce hot air from top to bottom of the case. Anyone tried it?
K kebbz Honorable Jul 27, 2012 212 0 10,680 Aug 2, 2013 #2 antiglobal : You will accomplish nothing. You will only have negative pressure inside the case, and the components will overheat. Has that really been proven? I dont get anything googling. Air gets sucked in from the side, and exits 2 ways? Upvote 0 Downvote
V Veske Honorable Jun 29, 2013 112 0 10,710 Aug 2, 2013 #3 Well the fans are not strong enought to suck in air from the holes that are open but fanless. So there will be a huge deficit of fresh cool air in your case. No need for a scientific research on such a topic probably. Upvote 0 Downvote
