Question AOC F22 Monitor not working
Dec 10, 2019
I got an AOC F22 Monitor and with a VGA to Display-port adapter. Always worked fine. Now that I removed the cable a couple of time to use a VR set, it doesn't work anymore. It will power on and give the blue light, say no signal and then swap to the orange light. I am using it as a second monitor next to my main monitor which is a Samsung on HDMI. My computer detects the monitor but it will just not turn on. I have tried everything. Please help.
First, I would try a different cable.
I think it's possible that removing it and replacing it may have caused a connection issue.
I would also inspect the vga and the display port at both ends to make sure they looked OK and there was no debris in them.
