Question AOC Q27G2U - No Sound from Speakers
dionisak00s
My AOC Q27G2U speakers do not work for some reason, I've tried changing the default device in windows, but nothing changes. I've downloaded G-Menu which is a software that comes with the monitor and I am unable to turn up the volume, the option is grayed out. Thanks in advance.
Edit:
My volume from the on-screen menu is set to a 100, in the G-Menu software it is set at 0 and is greyed out.
Just trying to clarify by, "changing default device in windows", you do mean "select playback device" from the drop down menu, which should appear once you click on the speaker icon on your desktop taskbar.
