Question AORUS B450 3.5 mm don't work..
Dec 3, 2020
Hello, yesterday i switched some parts and one of them was Gigabyte B450 Aorus PRO, everything was fine, but today i turned my pc and noticed that i don't have sound..
Then i started to searching for problem why.. And i found that my headphones with usb forks fine, and speakers with 3.5 mm don't work in back panel or front panel at all..
Tried to reinstall drivers, downloaded from motherboard official site, lastly i tried to reinstall OS, but result is same, usb device forks fine, but 3.5 mm don't work at all.. But if i go to „Realtek Audio Console“ and trying to change balance Left or Right then i hear some beeps or some noise.. So situation is that: Everything working fine, i shut down PC, go to sleep, wake up turn on pc and 3.5 mm dont' work.. Like some miracle.. i saw few others have similar troubles with B450 Aorus X.. So my motherboard is defected or what? Any ideas guys.. 🙁
By switch, are you stating that you swapped out the motherboard in place of an older platform? Did you recreate your bootable installer for Windows 10 using Windows Media Creation Tools? Can you get into BIOS and check to see what version you're on at the moment for your BIOS?
Make and model of your PSU?
On second thoughts, please list your specs in full and include the before and after specs, i.e, two sets of specs for your build.
Hi again :)
So builds are:
OLD
CPU: R5 2600
GPU: 1050 ti
PSU: Xilence 500w
CASE: some random prebuild case
MOBO: Asus A320M-K
RAM: Team Group Vulcan Z 16GB 3200MHz
SSD: samsung mzvlw256hehp-000l7
NEW
CPU: R5 2600
GPU: 1050ti
PSU:Xilence 500w
CASE: Signum SG1V EVO TG ARGB
MOBO:Gigabyte B450 Aorus PRO
SSD: Samsung mzvlw256hehp-000l7
Bios version is F50. About windows.. I don't use that software, in the work i have other OS downloader where i downloaded fresh newest updates windows ISO..
So basicly i just swaped case and mobo.. first day everything works fine, after night no sound in any panel of 3.5 mm..
