Hello,
I bought new components for my PC,but my WaterCooler is not working 100%
After i install the new cooler and start my pc, motherboard says:
"cpu fan speed detection error!
Please ensure your cooler is properly connected to the CPU_FAN header.
Consider dropping "CPU Fan speed lower limit"
or simply set if to "ignore" in BIOS if problem persists."
So after this info i accessed BIOS and i set ignore , worked.
After that i installed windows 11/MotherBoard Software, AORUS ENGINE 2.1.0 and RGBFusion 2.0 (Cooler Software).
But the problems persist, those are:
WaterCooler Display shows VRM, CPU temp at 00 Celcius and 0.0 Ghz CPU.
RGB Fusion 2.0 program doesnt work properly, i cant change the FANs color.
Could be the Firmware, mine is 1.1 and gigabyte website have 1.6 but i need to [Moderator edit to remove profanity.] buy a microSD + Reader and i dont know if will fix this issues or not.
Anyone with the same problems ?
any solution ?
Thanks.
PC SPECS:
ROG STRIX Z690-F GAMING WIFI
INTEL CORE i7 12700k
RAM DDR5 KINGSTON 5200MHZ
AORUS WATERFORCE X 240
MSI GAMING TRIO 2080 TI
SSD 500GB SAMSUNG
POWERSUPLY RM CORSAIR 850W
CASE NZXT H500i
BR,
CZAR91
any solution ?
Thanks.
PC SPECS:
SSD 500GB SAMSUNG
CASE NZXT H500i
BR,
CZAR91
