[SOLVED] Aorus Z490 Pro AX --- onboard graphics not working ?
Dec 27, 2021
hi,
I have an Aorus Z490 Pro AX firmware already updated lateste to F21 version. But, I cannot find any option to enable onboard HDMI.
There was no option to enable, and when plugin onboard HDMI, nothing happens also.
Try to update mainboard firmware, try to find it also in Device Manager (currently I plug into a dedicated GPU so it works with screen)
pls help
tks
  • Intel i7 10700F
  • ASUS TUF Gaming GeForce® GTX 1660 SUPERTM OC edition 6GB GDDR6
those are the specs I have
for the mainboard, even website said it has onboard graphics, but there is no way to find settings in BIOS
Intel i7-10700F doesn't have an integrated graphics chip.
Motherboard specs are slightly misleading. Motherboards no longer have "on-board" graphics, graphics support (without a dedicated graphics card) depends on the CPU model.
In any case, why are you trying to use the motherboard's HDMI port when you've got a graphics card ?
ahh thanks Philip and Lafong, it could be the case.
well, I just want to connect to another Monitor (4th one) while the current card already has all ports occupied
thanks for your help
