I haven't installed a CPU in years...many years. Back then, there were pins on the bottom of the CPU, and the big danger was not bending them when you pressed them into the socket on the motherboard. Obviously, a lot has changed since then.
According to instructional videos, there are supposed to be notches that align to the indentations in the CPU. And, there's supposed to be a marker somewhere on the motherboard to align with the triangle of the CPU. But, there's space at the top and bottom of the CPU...I expected a square tray for my square CPU, but I got a rectangular one. Should I replace the tray with a square one, or can it work like this? Hmm...I think I answered my own question.
Is the connectivity to the copper enough for it to work, even if it's not in exactly the right spot? There's no way I'm going to try it without knowing for sure. Note here that the rectangular area underneath the CPU could be made to line up. But, again, I'm thinking I need to get a new CPU tray.
Please let me know if my instincts about needing a new tray are correct, or if it can work as-is. Thanks!
