Hello!
I moved into a new apartment and connected to the internet through TWC (coax cable) with a modem connected to a router.
Every room has a panel with a coaxial connection and a port labeled CAT5e.
I was hoping to find a way to take advantage of the CAT5e wiring to connect my different devices in the other rooms.
I've searched for a while to find out where the cables terminate and finally found CAT5e cables in the basement (it's a condo, I'm on the 4th floor).
Only one cable is labelled with my apartment number on it, but there are a few other cables that are not labeled at all.
The cable seems to have some of it's internal wires connected to a box that says Verizon DSL and to another Telephony box but I'm not sure.
Here's a picture: http://i.imgur.com/1eGVzlk.jpg
This now feels way over my head-- can anyone either recommend what I can do or who I can talk to for help on this matter?
Really appreciated, in advance.
Yoni
Yoni
