APU A4 5000 driver problems
Kashish_1
7
So I have a Lenovo G505 and the specs are:-
A4 5000
4GB ram
1TB HDD
so the problem is that the latest driver for this APU is 14.4 and I have been having problems with this driver .. i also read many reviews and it seems to be a bad driver. So i dont know what to do as AMD has not made a driver for this APU after 14.4 and also I haven't found any option for A4 5000 when i go to select the driver manually on the website.
So should i use a older driver and if so how do i get a older driver coz i wasnt able to find it on AMDs site
yes but how .... i cant find older drivers on the AMD website
the problem is that i cant find the old drivers on AMD's website ... so if you know where to find the driver just before the 14.4 driver it would be very helpful ... thanks
