Question ARCTIC Liquid Freezer II 360 A-RGB vs Bequite Pure Loop 2 FX 360
domjam
293
7
18,785
I was orginaly going to go with be quite pure loop 2 fx 360. but due to the fact that i cant find this cooler anywere in stock..im looking for an alternative.
Would the Arctic liquid freezer II 360 A-RGB be a good or even better pick? i also need to know if it would be compatible and give me enough clearence with the following hardware. as i would want to mount it at the top of the case.
7600 x
Asus X670E hero
Kingston fury beast rgb
Lian Li Lancool III
Clearance info is there under 'spacious cooling support'. Don't skip to the bottom of the page.
LF II: 25mm thick fans + 38mm thick rad
It's the 140mm class instead of the 120mm, but the info from pages 6 and 8 can still be used to get an idea of what to expect.
