triplex1
Notable
The list I gave you is all ok with Arctic 360.but is there a way to find for example if my radiator is 63mm thick with fans i am able to find a case for that or gota manualy search ? Thanks
Ram, what do you have?but is there a way to find for example if my radiator is 63mm thick with fans i am able to find a case for that or gota manualy search ? Thanks
Phanteks XT Pro Ultra Mid-Tower it's ok , see the video of installationbut is there a way to find for example if my radiator is 63mm thick with fans i am able to find a case for that or gota manualy search ? Thanks
nice case as well plenty of space from motherboard to radiator+fans but a tight fit 😛
Phanteks has very good cases and the price now is low , take itnice case as well plenty of space from motherboard to radiator+fans but a tight fit 😛
so what would be a step up for bit bigger phantek case compared to the one uv linked ?Phanteks has very good cases and the price now is low , take it
Then you go to a full case and you go up in price too.so what would be a step up for bit bigger phantek case compared to the one uv linked ?
wherever you end up, search on youtube for installation with Arctic 360ill post when i decide what ones to chose from prob watch yt about em Thanks.
