[SOLVED] Are all Micro-ATX motherboard screw holes the same way?
Nov 21, 2020
4
I noticed my motherboard is different then the standard size for Micro-ATX motherboards, even tho it's labled as such. I did some reasearch and found out they can be slightly different sizes. One thing I can't find is wether or not the screw holes are still spaced the same way?
Thanks
The screw hole pattern is always standard. But some use 6 screws, some 5 screws, some only 4. And some use the upper bottom right hole and some use the lower bottom right hole, and some don't use either. It depends on the board design.
I guess the best way of saying it is the hole pattern is standard, but the holes used vary.
