Are all these parts compatable and any tips ?
MasterKempinis
59
My spec
CPU - Ryzen 5 1600
MOBO- Msi b350 mate motherboard
GPU- GTX 970
RAM- 8gb ddr4 3000mhz ram 2x4
STORAGE- 1tb hd
120 gb ssd
PSU- EVGA SuperNOVA 650 G2, 80+ GOLD
PC CASE- game max draco black
Are these all going to work well and this my first time building pc any tips that might help I have done lots of research and might know all of them but doesn't hurt to check twice
Thanks
I checked the case online and can't find the max PSU length for it. I found that it has a hard metal shroud at the bottom that fits the PSU and thus the cable management might be a bit tight. I think the G2 should fit. If it can fit a 360mm radiator, a PSU should not be a problem.
Oh ok thanks
Why ask for suggestions if you have no budget? I would skip the 120GB SSD, create a 200GB partition on the 1TB HDD to be your C: drive so that it is easy to migrate your C: drive to the 250GB SSD when you have the money.
