Are all these parts compatible?
Tyreese Sweeney
14
Optical Drive -
Hey guys, at the age of fifteen I have hopes of popping my cherry and to build my first computer. I've owned four in the past and I've always bought them.
I'm new to this tech scene, but I've always been interested since a ripe age. I've watched countless youtube videos on what to do, and I guess it also helps that my step-father is an auto-nut and is getting me into this type of stuff.
Bottom line, I just want to know if these parts are compatible, I'll be scrounging up money in order to build this computer, and I've already checked around the forums for help with a PSU.
Case - Cooler Master HAF 932 Advanced - High Air Flow Full Tower Computer Case with USB 3.0 and All-Black Interior - $140
GPU - EVGA SuperClocked w/ ACX Cooling 02G-P4-2774-KR GeForce GTX 770 2GB 256-bit GDDR5 PCI Express 3.0 SLI Support Video Card - $330
SSD - Kingston SSDNow V300 Series SV300S37A/120G 2.5" 120GB SATA III Internal Solid State Drive (SSD) (SSD) - $59.99
RAM - Kingston HyperX Blu 8GB (2 x 4GB) DDR3-1600 Memory - $90
MOBO - MSI Z97-GD65 Gaming LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard - $179
PSU - EVGA SuperNOVA NEX 650 G 80 PLUS GOLD Certified 650W Active PFC ATX12V v2.31/EPS 12V v2.91 SLI Ready CrossFire Ready Full Modular PSU 10 Year Warranty 120-G1-0650-XR NEW 4th Gen CPU Certified Haswell $79
Processor - Intel Core i5 4670K Unlocked Quad Core 3.4GHZ Processor LGA1150 Haswell 6MB - $240
Cooling -
CNoctua NH-U14S 140x150x25 ( NF-A15 PWM) SSO2-Bearing ( Self-stabilising oil-presure bearing ) CPU Cooler - $65
Cooler Master SickleFlow 120 - Sleeve Bearing 120mm Blue LED Silent Fan for Computer Cases, CPU Coolers, and Radiators (This is for the bottom portion of the case, it has room for fan which I plan on making it another exhaust considering it only has one stock exhaust fan in the back) - $7
~ $ 1229
I don't know if I will overclock, but I do want to be able to have the option.
turbolover22
214
9
The mobo doesn't appear to have a USB 3.0 header for the front panel. All of the USB 3.0 ports appear to be located on the back of the board.
And if you plan on installing/storing a bunch of stuff on your computer you may want to seriously consider upgrading your SSD to a minimum of 256GB.
Tyreese Sweeney
14
I have some spare 1terrabyte hard-drives I plan on using, I'm installing my OS to the SSD.
Also, it does have USB 3.0 headers, they're in the bottom right of the board.
