D difrio77 Prominent Feb 9, 2018 31 0 530 Mar 7, 2018 #1 I just RMA'D a motherboard and I don't have the cpu socket cover that came with it. I have a cpu socket cover from another mother board and both motherboards are lga1151 sockets will this cpu socket cover work ?
Solution M M mdd1963 Mar 7, 2018 hard to tell, it *might* work, as long as cover conforms to socket 1151 dimensions, they should be semi-interchangeable.... Proceed carefully, place on socket lightly, see if any tendency to shift when closing lock down clamping mechanism...
M mdd1963 Titan Jan 14, 2006 16,614 1,729 81,240 Mar 7, 2018 Solution #2 hard to tell, it *might* work, as long as cover conforms to socket 1151 dimensions, they should be semi-interchangeable.... Proceed carefully, place on socket lightly, see if any tendency to shift when closing lock down clamping mechanism... Upvote 0 Downvote Solution
bignastyid Titan Moderator Jun 19, 2011 33,688 1,700 159,590 Mar 7, 2018 #3 From what I've seen all the socket 115x boards use the same socket protector. Upvote 0 Downvote
