Are HyperX Fury 8GB DDR4-2400MHz (HX424C15FBK2/8) compitable with Motherboard ASRock AB350M Pro4 and Ryzen 5 2400G?
kjb21
5
Hello
i am about to buy Motherboard ASRock AB350M Pro4 (90-MXB520-A0UAYZ) and Ryzen 5 2400G but i already have HyperX Fury 8GB DDR4-2400MHz (HX424C15FBK2/8) 2x8 are they compitable with Motherboard and Cpu?
take a look on the motherboard QVL List, this lists all RAM that has been tested works with the motherboard
If the RAM is on the QVL List, then go with it, if not, search for another ram
mostly, even RAM not in QVL List will work, but if you worry about it, then stick with QVL List
i already search it threre but it doesnt exist thats why im asking
he says its compatible, for him tho, it may behaves different in yours
and as I have said, mostly, RAM will work regardless of QVL List, (well, i never heard of RAM doesn't work just because its not on QVL)
I have Gigabyte X370 Gaming K5 and 2x8GB 3200Mhz Corsair which is not on the QVL List and work just fine
