Are modular PSU cables interchangeable between vendors?
marktwayne
109
Can I use a Molex modular power cable that I received with a Corsair unit? Hypothetically, if I used the wrong brand cable, what would happen?
Wait are you trying to run 4 risers on one string of connectors? That is way too much load. Each riser...
No, modular cables are not interchangeable across units most of the times. Sometimes, for instance, different units of the same brand may have compatible modular cables, but most of the time it's a no. If you were to stick a modular connector in a PSU that's not compatible with it, the PSU should shut off from short circuit protection when it is turned on.
The connectors on the PSU end have no set standard. While they may be physically identical. They may have a different pinout at the PSU. You'd have to use a multimeter to test the PCIe, Molex, EPS, &c cables. To make sure they are providing the correct voltage to the correct pin.
Once you figure out which pin provides which voltage. You should be able to rewire the connectors on the PSU side of the cable.
So, no you can't just use any brand of cable. Even the same brand may not work between lines or generations. If you know what you are doing. You can correct the wiring.
MERGED QUESTION
Question from marktwayne : "SATA power from PSU to PCIE risers burnout issue."
It is probably most likely that the proper cables were sent. I have no reason to be suspicious other than the PSU was purchased second hand. This is only a minor possibility. Sure, a multimeter might help. What else would cause the SATA power cables to burn out? I have Molex running to the last three cards now and they seem to be running fine for now.
If in doubt, test the PSU and cables with the Dr Power II.
https://www.amazon.com/Thermaltake-Automated-Supply-Oversized-Supplies/dp/B005F778JO/ref=sr_1_fkmr0_1?ie=UTF8&qid=1517803542&sr=8-1-fkmr0&keywords=thermaltake+psu+tester.
At $40, it isn't the cheapest but it does test for proper voltage on all rails and cable types. And it's cheaper than blowing stuff out.
I separated these two questions intentionally, but they were merged by a moderator. I think I'll have to ask the question once again and hopefully the moderator will have the wisdom this time not to muddy the issue because of an extremely unlikely scenario.
I don't want to hear anything about incompatibility between SATA cables unless you are reasonably sure that incompatible SATA power cables is hands-down the most likely reason that SATA power cables fry in systems built with second hand PSUs.
Please note. This was asked as a hypothetical question. I have no reason to think the wrong cables were sent. I am simply trying to figure out why SATA power cables are burning out on my PSU. These SATA power cables are powering four risers.
Also, I had a brand new PSU fail on this system a month or so ago. It is possible that the burned out cables and failed PSU could be related.
Wait are you trying to run 4 risers on one string of connectors? That is way too much load. Each riser can draw 5.5 amps. One of those lines is rated for a combined 11 amps. SATA connectors are designed for up to 4.5 amps.
Use risers which support 6 pin PCIe connectors or at least 4 pin molex. With no more than two risers per 4 pin molex string.
OK. That sounds sensible. I have two types of risers, one has Molex and the other has 6-pin. Both types came with SATA converters, so I was only using two strings of SATA to power all six card risers. I knew too much power was likely causing the SATA power to fry, but I had no idea SATA power connectors really don't have enough power to reliably power even one riser.
Now, I am running the first string of Molex to the first and second card risers, a second string of Molex to the third and fourth card risers, and one string of PCIE 6-pin to the fifth and sixth card risers. Thanks.
SATA power connectors have three 1.5A power pins for a combined 4.5A. Some cards won't go beyond that. Radeon cards like you use will max out the draw on the PCIe spec.
Also the adapters risers generally come with are very low quality. Every advice column on mining I've read say not to use them when mining because of melting/fire hazard. Those low quality adapters use a press fitting rather than a crimp fitting. It's thought the press fitting puts the wires too close together resulting in arcing between wires.
The crimp fitting are much better made. Instead of a mold injection. Each wire is clamped in. Ensuring proper division. Although less of a risk. You still can exceed the AMP rating of the SATA connector. When you use a PCIe riser. Your new setup with Molex 4-pin and PCIe 6 pin is much better. All PCIe would be ideal.
