J jakubstaszel Reputable Dec 15, 2014 2 0 4,510 Dec 15, 2014 #1 Here is a link to some of the partstht i am thinking abouthttp://pcpartpicker.com/parts/partlist/ I am willing to change u some parts and it helps a lot if you reply. Thanks
Solution G Guest Dec 16, 2014 Please post the personalised link to your build. It will look like this: http://pcpartpicker.com/user/matt34323/saved/wvBzK8 Instead of http://pcpartpicker.com/parts/partlist/
G Guest Guest Dec 16, 2014 Solution #2 Please post the personalised link to your build. It will look like this: http://pcpartpicker.com/user/matt34323/saved/wvBzK8 Instead of http://pcpartpicker.com/parts/partlist/ Upvote 0 Downvote Solution
G Guest Guest Dec 16, 2014 #3 It would help if you fixed your link but a computer should run Mac OSX well if: 1. It has an Intel CPU 2. It has decent graphics. Upvote 0 Downvote
