Are My Parts Compatible?
PutNameHerePl0x
51
Power Supply: CORSAIR CX500M 500W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply ($69.99)
Motherboard:GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard ($129.99)
Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL ($62.99)
CPU: AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor FD8350FRHKBOX ($174.99)
Video Card: SAPPHIRE 100354XTL Radeon HD 7870 XT w/Boost 2GB 256-bit GDDR5 PCI Express 3.0 x16 CrossFireX Support Video Card ($249.99)
Case: NZXT Phantom 410 CA-PH410-W1 White Steel / Plastic ATX Mid Tower Computer Case ($69.99)
Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($74.99)
Monitor: ASUS VS Series VS228H-P Black 21.5" 5ms HDMI LED Backlight Widescreen LCD Monitor ($134.99
Odd. The 410 is rated for ATX form-factor motherboards, which are all of those dimensions. Perhaps the motherboard is mounted vertically? I must admit, I've never owned or used that particular case, nor any of mid tower, in fact.
you're looking at the wrong demensions. the motherboard is 9.6inchs wide going from the back panel to the drive bays. the case is 8.46 wide going from one side of the case to the other (looking straight at it from the front panel)
10 dollars without the promo code, the choice is yours to make, 500w psu to make it work today and not work down the road if you upgrade to more HDs, a better gpu or OC, or spend a few more dollars on something you know will power your pc for awhile to come. If you don't plan on upgrading the 500w psu will do you just fine. remember even having just 6 fans in the case uses 3-4 amps, and lets say you have a 40A 12v rail, whats availabe is lets say 35A x12v = 420w, your cpu is 125w twp, and your 7870 can pull upwards of 225~W(max load) so that right there would be your 350W, thats not factoring in any OC as well as your HD. Like i said it will work and heck even with a mild overclock, but with electronic degradation it might not last that long.
You are wrong. Look at the picture in the link http://www.newegg.com/Product/Product.aspx?Item=N82E16811146087
The MB will fit in the case.
just how was i wrong? you should reread my statement. again he was looking at the wrong demensions.
I plan on getting a new one eventually, just not right now as I spent my budget and more.
Well it's 12" x 9.6" so what does the 12 mean then?
ok ill try to put it in a picture
mobo
|----------------|<--- 9.6 inchs wide
|<---12 inchs long
What you may be missing, from his perspective, is that the width of the case is 8.46 inches. This is the source of his confusion.
Yes, that is exactly what I'm confused about.
Look what I found: http://www.tomshardware.com/reviews/mana-136-midgard-ii-phantom-410,3203-5.html
I was right, it's mounted vertically and the motherboard will fit. You're in good shape.
its how most are?
anyway the width of the case meaning 8.46 or wahtever
|----------|<--width of case (8.46 inchs or whatever)
|<--height of case
Unfortunately, a lot of folks here are armchair designers who've never actually assembled a computer. For what it's worth, I do design my own rigs, but a neuromuscular condition makes my fingers less useful for fine manipulation than I'd like when working with expensive electronics.
Yeah this is my first time making a computer.
