I ishraq.hassan.94 Sep 6, 2018 1 0 10 Sep 6, 2018 #1 I want to use antec vp 500w pc ec psu on my new case tharmaltake versa h25 . Will it fit ?
Solution R R Rexper Sep 7, 2018 PS/2 power supply form factor is the same as the standard ATX. Its standard measurements are 150mm width x 86mm height x 140mm (or longer) depth. The Antec VP500PC measures 150mm W x 86mm H x 140mm D. The Thermaltake Versa H25 supports a standard PS2 PSU. Your PSU will fit.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,105 912 120,140 Sep 6, 2018 #2 Yes it'll fit, but I don't see what PS2 has to do with it. Upvote 0 Downvote
R Rexper Respectable BANNED Apr 12, 2017 2,131 2 2,510 Sep 7, 2018 Solution #3 PS/2 power supply form factor is the same as the standard ATX. Its standard measurements are 150mm width x 86mm height x 140mm (or longer) depth. The Antec VP500PC measures 150mm W x 86mm H x 140mm D. The Thermaltake Versa H25 supports a standard PS2 PSU. Your PSU will fit. Upvote 0 Downvote Solution
