[SOLVED] Are the parts of this PC build compatible?
They are all compatible but I would make a few changes such as the PSU as it's way more then you'd need for that build. Also the only spot for that AIO is in the front of the case which will dump more heat in so I'd change it to a case that has it as exhaust. The SSD you can get a faster model for cheaper.
WildCard999
Reactions: DaBenschi
6
Ok thank you very much i'll try to change the things you told me :D
