Are these parts compatible/reliable?
Dec 15, 2012
4
Hey everyone. This will be my first build and I am still a little worried about compatibility.
i5 3750k
ASRock P67 Pro3 SE ATX
Crucial BallistiX Sport 8GB
OCZ Vertex 4 SSD 128GB 2.5in.
Sapphire Vapor X 6850
Antec Three Hundred Two
Corsair Builder Series CX600
HP Wireless Elite V2 Keyboard
BenQ GW2250 22in
Is that a good GPU for gaming at 1920x1080 while playing NFS Most Wanted, Minecraft with GLSL shaders mod, Left 4 Dead 2, and some newer games at slightly lower settings? Is that PSU good enough and does it have enough cables for everything? Is that a good motherboard for overclocking a little bit? Is that GPU going to take up more than one PCI-E slot? Is the case big enough for my parts and will airflow be a problem? Is that SSD reliable enough to use as my main drive with storage on an external drive? Does that case need a 2.5in mounting bracket?
Sorry for all my questions as this is my 1st build but thank you in advance.
Dec 15, 2012
4
Is their anything wrong with the corsair? They carry it at a local Best Buy and I'm partial to corsair because multiple friends have this one and they like it alot.
The links aren't working. But to answer your questions:
-That GPU is bare minimum for 1080p gaming. I would get something more robust like a 7850, but I realize you probably have a budget. Post a budget and we can offer better suggestions.
-You can OC with that motherboard, but it isn't a good motherboard for OCing. The minimum board I suggest for OCing is the ASRock Z77 Extreme3 (but at that point just get the Extreme4 it's worth the extra $10). Again, I realize you are on a budget.
-The PSU is fine, it has enough cables for one powerful GPU.
-The GPU only plugs into one actual slot, but takes up two slots space.
-The case is adequate for most configurations - it specifies how big a CPU cooler you can put in and how long a graphics card you can put in on the amazon page.
-The OCZ Vertex 4 is a fine SSD for a main system drive.
-Don't forget a CPU cooler. CoolerMaster Hyper 212+ (or EVO) are good value coolers.
Dec 15, 2012
4
Thank you for the recommendations. I will probably start from square one again. I will get the Extreme 4 and probably bump up my gfx card. Thanks a bunch!
