Hi everybody,
I'm building a computer for my friend, and just wanted to check if these parts are compatible with each other. Any recommendations that you have would also be great. I'm trying to keep it very cheap--like 500-600 dollars-- so if you can help make it any cheaper, feel free to help. Thanks
CPU: Core i3 2120: http://www.amazon.com/Intel-i3-2120-Processor-Socket-LGA1155/dp/B004KZDV8E/ref=sr_1_1?s=electronics&ie=UTF8&qid=1335486251&sr=1-1 (122$)
GPU: Radeon HD 6770: http://www.amazon.com/XFX-Radeon-HD6770-PCI-Express-HD677XZNLC/dp/B004Z5GRVW/ref=sr_1_1?s=electronics&ie=UTF8&qid=1335486227&sr=1-1 (110$)
RAM: Patriot Gamer 2 DDR3 8GB 1333MHz: http://www.amazon.com/Patriot-Division-PC3-10666-9-9-9-24-PGD38G1333ELK/dp/B004GUT330/ref=sr_1_1?s=electronics&ie=UTF8&qid=1335486194&sr=1-1 (40$)
Motherboard: ASRock Z68 LGA 1155 ATX Intel: http://www.amazon.com/ASRock-Z68-PRO3-GEN3-Intel/dp/B005N5Q2MW/ref=sr_1_1?s=electronics&ie=UTF8&qid=1335486147&sr=1-1 (105$)
Power Supply: Antec EarthWatts Green 650W ATX12V: http://www.amazon.com/Antec-EarthWatts-EA-650D-Green-BRONZE/dp/B004NBZAES/ref=sr_1_2?s=electronics&ie=UTF8&qid=1335486104&sr=1-2 (65$)
Case: NZXT Guardian Black SECC Steel Chassis ATX Mid Tower: http://www.amazon.com/Guardian-Black-Steel-Chassis-921RB-BL/dp/B004351H9G/ref=sr_1_1?s=electronics&ie=UTF8&qid=1335486082&sr=1-1 (70$)
HDD: Seagate Barracuda 500GB 7200RPM: http://www.amazon.com/Seagate-Barracuda-3-5-Inch-Internal-ST500DM002/dp/B005CT56R6/ref=sr_1_1?ie=UTF8&qid=1335486052&sr=8-1 (80$)
DVD: Asus 24x DVD Burner : http://www.amazon.com/Asus-24xDVD-RW-Serial-Internal-DRW-24B1ST/dp/B0033Z2BAQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1335486010&sr=1-1 (22$)
Total: 617$
Total: 617$
