Are these parts good for gaming?
naj_02
28
CPU: Intel Core i3 4150
RAM: Gskill Aegis 4GB 1600mhz DDR3
MOBO: Asrock H81M HDS
Chasis: EsuperCase 500w
GPU: Palit GTX750 StormX OC 2GB DDR5
and about the storage, should i buy a ssd or hdd or both of them?
This might be good:
PCPartPicker part list: http://pcpartpicker.com/p/XbHL3C
Price breakdown by merchant: http://pcpartpicker.com/p/XbHL3C/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor ($49.99 @ Micro Center)
Motherboard: Asus H81M-A Micro ATX LGA1150 Motherboard ($47.60 @ SuperBiiz)
Memory: GeIL EVO Veloce Series 8GB (2 x 4GB) DDR3-1600 Memory ($40.99 @ Newegg)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($35.70 @ SuperBiiz)
Video Card: Asus GeForce GTX 650 2GB Video Card ($52.45 @ SuperBiiz)
Power Supply: SeaSonic 400W 80+ Bronze Certified ATX Power Supply...
Hello,
It really depends on what type of games you want to play... But generally, no, those parts will not make a very good gaming PC:
The I3 CPU isn't so bad, you can survive without an I5.
You really want to have 8GB RAM at least for gaming nowadays.
I assume that 'Chasis' is a 'Case + Power supply combo'...? I've just checked the Tom's Hardware PSU tier list, and using CTRL+F I found SUPERCASE from Apex under Tier 5. This means that your PSU is unsafe, as quoted here:
"Tier Five
Avoid IMMEDIATELY. These units are highly unsafe to use. No such protections added, very thin gauge wiring used, false advertising and too much to list. Reference to a higher tiered unit for a better, money saving and a much safer unit. For your safety's sake, please don't order or pick one up for use in your system. These units are a potential fire hazard and could even kill you, let alone your system."
Finally, the GTX 750 is getting quite outdated now and will struggle to cope with new games even at low settings, though it is possible.
If you could tell me your budget, tell me exactly what components you need (also say if you need a monitor, mouse, keyboard, operating system), and tell me what games you want to play, I will try to build the best PC I can, for you.
May i ask you how much is your budget?
This might be good:
Power Supply: SeaSonic 400W 80+ Bronze Certified ATX Power Supply ($38.25 @ SuperBiiz)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive ($11.90 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($80.89 @ OutletPC)
Monitor: *Acer G226HQLBbd 60Hz 21.5" Monitor ($89.99 @ Amazon)
Total: $447.76
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2015-11-30 13:57 EST-0500
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor ($59.99 @ Newegg)
Motherboard: MSI H81M-E33 Micro ATX LGA1150 Motherboard ($39.10 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($29.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($39.10 @ SuperBiiz)
Video Card: Zotac GeForce GTX 750 Ti 2GB Video Card ($93.99 @ SuperBiiz)
Case: Rosewill FBM-02 MicroATX Mini Tower Case ($19.99 @ Newegg)
Power Supply: SeaSonic 350W 80+ Bronze Certified ATX Power Supply ($30.60 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($81.60 @ SuperBiiz)
Monitor: Acer K202HQL 60Hz 19.5" Monitor ($69.99 @ Micro Center)
Total: $464.35
Generated by PCPartPicker 2015-11-30 15:58 EST-0500
