are these parts good?
kurulay5
125
i think I've been at this for a year now and after learning about pc and trying my hardest to find the best budget build i came to a conclusion of this
https://uk.pcpartpicker.com/list/T24gKB
it adds up to £402
my case supports the micro atx
the motherboard supposedly supports ryzen 3 2200g
i am NOT getting a gtx 1050 ti because i think its just unnecessary considering the heaviest game I've played was heroes and generals
the game i play the most is definitely osu!
now i just want to make sure all the parts are perfect it all works everything is good no problems or anything
or is there something CHEAPER i can get which offers the same or better performance in the list above
currently im rocking (i say rocking but these are all trash)
CPU: AMD A6-7400K Radeon R5
MEMORY: 1x8GB DDR3
GPU: AMD Radeon R5 Grapchics
MOTHERBOARD: F2A68MH-HD2
Ryzen performs better with faster RAM. This should offer better performance...
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor (£86.39 @ Aria PC)
Motherboard: MSI - B450M PRO-VDH Micro ATX AM4 Motherboard (£64.99 @ CCL Computers)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory (£83.05 @ Amazon UK)
Video Card: Gigabyte - GeForce GTX 1050 2GB D5 Video Card (£118.49 @ Ebuyer)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply (£47.99 @ Amazon UK)
Total: £400.91
Generated by PCPartPicker 2018-10-26 23:10 BST+0100
It looks pretty good as far as compatibility. I think it's great when people pick out their own parts even if they aren't exactly the "best for the money" because perhaps you like the MSI GAMING X gpu instead of a cheaper model of a faster GPU. It can give you that sense of personalized custom feel about your rig because you picked out every single part yourself.
I know you said you didn't need a better GPU, but you might feel differently later on. Here are some build with the Ryzen 3 1200 (can be overclocked) and a faster GPU and faster memory for around the same price. I didn't really check shipping costs though.
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor (£71.99 @ Aria PC)
Motherboard: MSI - B350M PRO-VDH Micro ATX AM4 Motherboard (£50.99 @ Ebuyer)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory (£68.99 @ CCL Computers)
Video Card: XFX - Radeon RX 570 4GB RS XXX Video Card (£169.00 @ Amazon UK)
Total: £408.96
Generated by PCPartPicker 2018-10-26 23:08 BST+0100
Motherboard: ASRock - B450M-HDV Micro ATX AM4 Motherboard (£63.06 @ Ebuyer)
Video Card: Palit - GeForce GTX 1050 Ti 4GB StormX Video Card (£137.99 @ Aria PC)
Total: £404.42
Generated by PCPartPicker 2018-10-26 23:11 BST+0100
MERGED QUESTION
Question from kurulay5 : "will this work?"
Honestly, I REALLy recommend that you save a while longer, add about another 200 pounds to your budget, and then you can get into a much better configuration that is going to actually last you a good while longer including as mentioned, faster RAM which makes a noticeable difference on Ryzen, a higher end CPU, a better board and probably also a better card.
Obviously, it's your choice, and what you have picked out currently will certainly work, and will be better than what you have now by a long shot, but adding a bit to the budget is going to result in a much better build that you're not going to be looking at in six months going damn I wish I had just scraped together a few more bucks when I did this.
is there much difference in the MSI - GeForce GTX 1050 2GB GAMING X 2G Video Card
and the Gigabyte - GeForce GTX 1050 2GB D5 Video Card ?
They all perform around the same range. I would get the cheaper one from a reputed brand as listed above.
Any of these builds and parts will be fine. The biggest worry I'd have from the entire build is the low quality nature of the motherboard you have selected. When you buy the cheapest motherboard in any given chipset, that is EXACTLY what you get. A cheap board. Usually, these are the people we see the MOST here, wanting to know why they can't game at a high level even though the rest of their hardware is just like somebody else's except the motherboard, and that shouldn't matter should it?
Yes, it matters. Every step up you take gives you less probability that you will be dealing with issues related to the motherboard, and since problems with the motherboard are extremely difficult to positively identify without ruling out EVERYTHING else first, reducing the chances that you'll have that kind of problem is a really good thing.
im not going to be overclocking and im not going to be doing major gaming
if u do manage to find something better then tell me please
