Are these Temps okay ?
Hayden Ross
112
Just got a new aftermarket cpu cooler , the h212 evo from coolermaster. I have a amd fx-6300, while on idle with this cooler im at around 20 celsius, and while running guildwars2 im at 30 celsius, now my house is air conditioned very well so this could explain why its running colder than i thought it would. I just would like some feedback on if this these temps are okay.
(also have the thermaltake chaser mk 1 case if that helps )
thank you
Wanted to make sure they were okay ^.^ ran prime95 for a hour temps never went over 32 celsius so i should be good to go :) thank you for the feedback :)
Latest posts
