Are those temps normal for summer?
Jan 10, 2015
649
So im a bit worried about summer and i want your advice about the temps! Are those okay?
i5 4690 3.9 ghz with stock cooler:
Idle at 33 degrees 100% load while Rendering a video i was getting 72 degrees but when i was gaming at 100% usage i was getting 65 degrees!
GPU=gtx 960 4gb windforce
Idle at 36 degrees (fan runs at low rpm at idle)
Max load while overclocked and also witcher 3 max settings 100% is at 67 degrees
Mobo=MSI b85m g43 idle is at 33 degrees while gaming is at 42
HDD=Caviar blue by WD is at 38 degrees
1 tb toshiba is at 32
1ssd ocz agility 3 is at 30
Are those temps normal?
AMBIENT TEMP IS 29 DEGREES
also 80c is the throttle point for Maxwell cards (Kepler too) boost speeds. The biggest reason i overclock nvidia gpu's with that temp in mind.
Considering that ambient, and just the performance of those coolers in general, those are okay temps. the idle temps look great, and the max load for the chip, does not strike me as abnormally warm considering video rendering is brutal work at times. the GPU temps are fine.
not at all high. yes the gtx 960 is generally a cool gpu but hitting 70C under full load is hardly unusual. In fact you have some thermal head room to overclock your gpu. Generally i say keep GPU's < or = 80C but nvidia lists the max temps for maxwell at 98C. Point is you're are safe by a lot of degrees.
