Hello, need little help to get ARGB fan lights to work properly on Gigabyte Z590 motherboard.
I have the cable(for the fan light) connected to the motherboard, but fans are spinning in one colour(orange) rather constantly switching to different colours automatically.. and I think it's due to the fact that Gigabyte motherboard require different ARGB fan light connector on the motherboard because they worked fine on my previous Asus/MSI motherboards.
I have Gigabyte Z590 Aorus Master in CoolerMaster H500 case(which has two 200mm ARGB fans) and there are two different types of ARGB fan light cables.
One of the ARGB fan light cable is 4pins which is the one I've used on different motherboards so far without any issue, and that's the cable I'm using on Gigabyte Z590 atm.
i.e. I have the 4pin ARGB fan light cable connected to "D_LED1" on the motherboard atm.
But CoolerMaster fans have another ARGB fan light cable which is 3pins and there's a little marking on that fan header which says "For Gigabyte".
I never had to use this ARGB fan light cable(3pins) on previous motherboards, but I assume this is the one I have to use for Gigabyte motherboard?
But if that's the case, I'm still not sure where(on the motherboard) I need to connect this cable.
Any advice would be much appreciated, thank you.
