Question ARGB fans not lighting up.
SethS
427
I purchased 7 matching ARGB fans, and was told "yeah, they'll work in a daisy chain connected straight from the PSU's 3 pin connector." Sadly it doesn't seem to work for me. My GPU lights are also ARGB and it turns on when directly connected to the PSU, yet none of the fans do, so i'm not sure what to do. Thanks
The connection to the chain of fans would be from the MOBO's 3-pin ARGB header, NOT from the PSU. What mobo do you have?
Sorry for the long reply, busy with work. I use a NZXT B550, I have it plugged into the motherboard's 3 ping argb header too. The NZXT CAM software shows that the header is "open" with up to 40 argb devices able to be connect to it, but shows I havent used it yet. I bought a controller to plug them all into and haven't gotten anything either.
