After a lot of reading various posts, I still cannot figure this out. The title mentions the two components in question. I am trying to get the RGB in the 3 front fans that come with the Lancool 2 to sync with my motherboard. The fans are connected with power through SATA and to the motherboard through the 3 pin ARGB connector (I've checked this connection twice). There are two buttons on the case, one for color, one for mode. According to the manual you need to be in the 8th mode setting for the ARGB from the mobo to control the fans, but when I go on that mode, it's just black. The ARGB even shows up in Armoury Crate, Asus's RGB software, however, when I configure it, nothing happens.
All the other color modes work, it just seems like something is wrong in either the software for the ARGB or the connection itself. I tried looking at the other end of the ARGB connector but it seemed like it was solidly plugged in.
Any ideas?
Any ideas?
