Hi there,
I got a Lian Li Lancool II Mesh RGB (which came with 3 RGB fans), a Galahad 360 Aio and the Lian Li RGB strip especially made for this case. They are all connected to the 2 argb headers on my Z690 AORUS Master.
My AIO is mounted at the front and the 3 fans' rgb cables are connected to the front panel, just like the RGB strip.
The front panel itself is connected to one aRGB header, so 1 is already occupied and I don’t wanna change anything on this header as it is also connected to my case to change lighting without software.
The 3 fans that came with the case are mounted to the top (2x) and back (1x) and their rgb cables are daisy chained.
I used a splitter cable that came with the AIO to daisy chain the AIO pumps rgb aswell. So they share the 2nd header.
Now I ordered a new GPU (GALAX/KFA2 4090 SG OC) which also comes with RGB lighting and an ARGB anti sag bracket (https://www.kfa2.com/support-stick-guide) and an optional 4th fan with rgb aswell,
What's the best way to connect my new GPU and brackets RGB to my mobo?
Sadly I couldn’t find any info on how much power the GPU, bracket and additional fan‘s RGB needs.
Would it be safe to daisy chain the GPU to my 2nd header, where the 3 case fans and AIO pump are connected?
Or should I get an aRGB hub, if so which?
According to the manual Gigabyte rates each argb header as 5A and a maximum number of 1000 LEDs.
''The headers can be used to connect a standard 5050 addressable LED strip, with maximum power rating of 5A (5V) and maximum number of 1000 LEDs.'' -manual
I hope someone can help me solve my issue.
And sorry for any mistake, english is not my 1st language.
I wish everyone a good day
