Archived from groups: alt.games.neopets (
More info?)
daramark wrote:
> "any1" <someone@somewhere.net> wrote in message
> news:42db4c34$0$60257$e4fe514c@news.xs4all.nl...
>>Hello,
>>I have gone as far as level 2 in the Dungeons and from the map at idnq I
>>see there is a massive transporter maze. I am not quite sure I understand
>>all the guides on this one. I have tried a search with Google but am not
>>getting farther there neither. Anyone have a good help for this part of
>>the Dungeons? Or know where I can find one (or more)?
> OK, using the map here (they show both ends of the teleporters and have them
> both the same # so if you go into #8 (you don't need #8 it's just an
> example), you look for the other #8 to find out where you are)
http://www.digifort.com/idnq/index.php?page=maps&map=114
> the quickest way is: teleporter 4 (the first one you come to) which leads to
> the other end of it that looks right next to it but separated by a wall.
> Walk the path over (and up) to #5 which takes you to the bottom right of the
> maze. Walk the maze past the first exit (leads to #2, don't need it) and
> then up and over to the left to #1. That takes you to a hall where the only
> other teleporter is labled "G" because it takes you to Gors. Gors is level
> 20. Try to be level 22 or better than that 23.
> Losing sends you back to Neopia City. Not bad here, but later on it's
> really annoying.
> Definately go and get the weapon upgrade after beating Gors!
> They say to be at least two levels above the bosses when you fight them. A
> few of them I needed more than that. I think that I lost to both Gors and
> Rollay, level 25 (I had to have been level 28 when I beat him). Funny thing
> about losing is that they take some Experience points from you. If you have
> just gained a level they can't remove it from you so you only lose
> Experience points down to the level up mark.
> Hope this helps, let me know if it's still confusing,
> daramark
Thanks for that. I had figured that out already. I am quite far and
walked all the numbers, for the sake of upping my level;-)
I am now level 23 and making my way to the G....
The weapon upgrade I get from Denethrir. right? I have all the items I
need so it should not be a problem.
Thanks
Henny
