So my situation is that with my components below my build will power and where I expect it to boot it does not. There are no beeps. and nothing shows on my Monitor. This is what I have;
- Old processor AMD Athlon 64 x2 6000+
- New MB Asrock 960GC-GS
- Enermax Tom. 500W PSU
- 4 GB DDR2
- GPU (none atm)
- 500GB HD used
- x24 DVDR used
- Going to install Win 8.1
I have read and tried all the trouble shooting guides available on this website. I have
- checked CPU direction, Thermal paste, and made sure it is clamped down properly
- Made sure 4pin connector is hooked up
- Tried booting with just MB, CPU, PSU, and monitor
- Tried booting with RAM and without RAM
- Checked spacer pins (or whatever they are called 😀)
- Removed PSU and tried
- Removed MB, PSU and tried
- Tried booting with only CPU fan hooked up
So basically I am wondering if its safe to say that my MB might be DOA or am I missing a step? I just removed my CPU today and it was working fine in my old computer. Any help would be appreciated. Thanks
- 4 GB DDR2
- GPU (none atm)
- 500GB HD used
- x24 DVDR used
