[SOLVED] asrock b450m pro4 with G.skill ripjawsV 3000 mhz 16 gb compatibility
Dec 27, 2018
4
I bought g.skill ripjawsV 16gb but after checking the asrock b450 pro4 qvl i couldnt find that ram. Does that mean that my ram wont work or something?
If the memory meets the specifications of the motherboard, but it's not on the QVL list, then that means that the manufacturer of the motherboard hasn't tested it and qualified it for the motherboard.
That doesn't mean it won't work.
You will have to try it and see.
Many times, in this situation, it will work.
