Question ASRock B550M Pro4 - - - BOOT LED lit after PC crash ?
4
Hello everyone,
I was playing dota2 and then suddenly my 1-year-old PC crashed. When I tried to turn it on again, the system did not pass the POST, with the BOOT led lit solid. I can't even enter the bios. I left it on for an hour but nothing changed. I did check for hardware failure, with only 1 RAM stick, switched RAM between sockets, booted on minimal hardware config (CPU and 1 RAM only), and tried to use bootable USB sticks, but it still failed on boot post. Can you help me with this?
I have a system with this spec:
ASRock B550M Pro4
AMD Ryzen 5 5500
2x8Gb Ram
ASRock RX 6500 XT
Thank you
Do you have access to another PSU? Yours is of very questionable quality.
Unfortunately, I don't. I think I will ask my friends if they have one.
reset the BIOS by jumper clrCMOS while power is off and try minimum config again.
M.2 SSD and SATA HDDs not connected, one RAM in slot B2, plus CPU, GPU, PSU
edit:
no USB flash drive connected as well
I did this and still nothing happened. I think I will try to claim my warranty and let them check my mobo and cpu.
