Asrock b85m pro3 overclock question
Marto492
25
Hey, i recently built my pc with this motherboard and a I5-4690k. My question is, can i overclock my cpu with this motherboard? Here is a link of its specs: http://www.asrock.com/mb/Intel/B85M%20Pro3/
For OC need good motherboard and Z chipset, but on some motherboard B\H chipset OC possible and this feature called "non Z OC". You motherboard no information.
And:
i
Very weak motherboard. OC bad idea.
Install last bios and try OC.
Your motherboard very simple. No recomend OC.
84W limit for this motherboard.
But if you want OC and problem not scare you, you must search non Z OC.
But i not found information on this motherboard:
P85 Pro3
B85 Pro4
BIOS Support Non-Z OC with K series CPU.
B85 Pro3
No information.
I not recomend, economy on motherboard in the future.
And:
i
Ok, i got you. I bought this mb on a tight budged and this was the best deal with 4 slots for ram. I am not into OC'ing but just a little oc to like 4GHZ or 4.2GHZ Is it bad? I mean is it going to harm my parts?
