Hi,
I'm building a small project for light / casual gaming based on an ASRock DeskMini x300 and I've few questions to finalize it.
For now, I've already the following components installed inside :
What I've but still to install :
The 1TB M2 SSD contains Win 10 and will be used to run most of the programs. I wanted to add a SSD heatsink and was thinking to pick the be quiet! MC1 PRO but after some readings, it seems that it'll not fit with the Noctua due to its screws.
My first questions are :
I've also the intention to add a second SSD with a capacity of 2TB. The goal will be to store the games on it.
I'm thinking to use the M2 slot at the back but it'll not be possible to add a heatsink (not enough space).
So my other questions :
Last question : in order to apply the thermal pads on the SSD's, should I first remove the sticker ? I read that some say yes and some yes no as these stickers are designed to dissimate the heat.
Best regards,
K.
- Ryzen 3 2200G
- Noctua noctua NH-L9a-AM4 which I set in the BIOS to run as standard (as opposed to quiet)
- Kingston NV2 NVMe PCIe 4.0, SSD 1 To
- G.Skill Ripjaws F4-3200C22D-16GRS (2x8GB)
- Intel Wi-Fi 6E AX210 M.2 non vPro
- 2 x Delock Antenna Cable RP-SMA jack bulkhead ferrite core to MHF (10cm)
- 2 x Delock WLAN 802.11 ac/a/b/g/n Antenna RP-SMA plug 4 - 5 dBi omnidirectional with tilt joint
- 5600G to replace the current 2200G
- Is a heatsink necessary ?
- If so, which one would be adequate for my install and can be installed alongside the Noctua ? I've seen Alphacool HDX M2 SSD M1 or Gelid Solution Subzero M2 SSD but maybe there are better options.
- Will cooling be required on this one ?
- If so, how to do it ? I read somewhere that using a 3mm thermal pad would be enough to make the contact with the back plate in aluminium and dissipate the heat. Would this be sufficient ?
Best regards,
K.
